Hand Tools
Re: Dimensioning: Question about roughing planes
david weaver
Wiley, as a matter of practice, somewhere around 2 times as far as the thickest shaving I intend to take or a little more, unless you have really easy going or only cross grain work, and then you can set the cap iron back as far as you'd like. The shavings don't show any influence from the cap either way.
Only really nasty stuff requires the cap to be set close on the jack. Quartered curly cherry comes to mind (I can only think of twice that I've had to do it).
I do work the try plane with the cap engaged, and it's set so that it straightens out about the thickest shaving I'll take in a given piece of wood.
There is quite a bit of extra resistance when setting the cap iron on the jack close, I guess because of the stiffness of the shavings, or I'd do it more often because it does eliminate surprises. Even given that, it does reduce risk and effort vs. the fight that occurs if you try to jack plane something like that without setting the cap close. Nothing adds effort like having to make something twice.
Messages In This Thread
Whelan planemaking book?
Re: Whelan planemaking book?
Can't answer about the Whelan book
Thanks (NM) *NM*
Re: Whelan planemaking book? *LINK*
Nice Article!
Re: Nice Article!
Do you profile your cap irons?
Re: Do you profile your cap irons?
Nicholson
Fun with math
Where did the ball go?
Re: Where did the ball go?
Focussing on the key point
Re: Focussing on the key point
(Message Deleted by Poster)
No worries *NM*
Reference: Peter Nicholson, 'The Mechanic's Compa
Peter Nicholson plate XII, pages 91 to 93 *NM*
Re: Reference: Peter Nicholson, 'The Mechanic's C
Re: Reference: paragraphs 3 and 4 *PIC*
Errors or suboptimal statements in books
Everybody makes mistakes
Re: Everybody makes mistakes
Things that can be out of date, too
Re: What is the title
Thanks Patrick *NM*
