Turning Archive 2008
Re: Lathe Lighting....Response To:
Lathe Lighting.... () Richard Allen
>You can't beat the light stand now sold by Oneway. The whole thing holds two lights, can swing to either side of the tailstock, is designed to mount on the oneway rail and has an electrical outlet for power sanding or whatever.
Better is the dust hood which can eliminate airborne dust while sanding at the lathe. The stud mounts for the moffit lights work great mounted to the dust hood. The dust hood rides on a rail which lets you move the hood from the inboard side to the outboard side (for use on either side of to get the hood out of your way is necessary, you can spin a 24" piece of wood with the hood in place).
Messages In This Thread
- Lathe Lighting....
- Re: Lathe Lighting....
- soaking wet
- Danray Products *LINK*
- Thanks Everyone...
- Belly light...
- Moffett's rule! *PIC*
- Re: Lathe Lighting.... *PIC*
- Bill Grumbine has a nifty setup
- soaking wet
