Turning Archive 2008
Re: dust collection at bansaw.
Russ Fairfield
>You will have better luck at getting more of the sawdust with 2 collecting locations. One at the point you already have under the blade, and the other at bottom dead center in the front of the bottonm wheel cover door. If you only had one collection point, you would most likely find that the one at the bottom of the wheel cover door would do the most good.
Yes, it is in the way, but with the way these saws are made, there is no easy way to locate it on the back side of the bottom wheel cover.
