Turning Archive 2007
Re: moisture meters
moisture meters ()
George Van
>Carol, I use a Wagner pinless electronic moisture meter when necessary. I have it for lumber use and therefore I can double its use. I also have a balance scale left over from or bakery. I use this more to monitor the drying weight of the item. When it stops loosing weight it is ready to use or move to a dryer environment if a lower moisture content is necessary.This is as helpful and as the moisture meter if I did not already own a moisture meter.
