Turning Archive 2004
Re: Need for vacuum guage?
Need for vacuum guage? ()
Bill Howatt
>IMO it is silly to use a vacuum chuck without a guage. How do you know what the vacuum is inside the chamber? You should have a valve that permits you to bleed a little air into the vac chuck so you don't pull maximum vacuum on large thin pieces - it will break it.
You can find guages for $10 or less.
You should also have some kind of a filter on the inlet to keep small garbage from getting sucked into the pump and possible ruining the vanes or other guts.
Bill
