Turning Archive 2002
Band Saw Blades &.....Paul Keller
> I use a 14" Delta with a riser block to cut bowl turning blanks from half a log. I would like to know what brand blade and what tooth you are using and would recomend.
Also in the center of the table is a 2" dia insert -this insert has moved on me when I am cutting a log and I end up cutting it (them to be honest) in half. What am I doing wrong?
Wish I were closer for the Jamborie sounds like a blast but Minnesota is a long haul. The weekend before (Sept 27-29) I will be in PA. For a session with David E. hope to meet some of you guys then.
Thanks, Paul
