Turning Archive
Re: drilling 1" holes
drilling 1" holes ()
jake niedling
I'm thinking that the ends are not 90 degrees to the 1" hole. I took a look at the item you are making from PSI. If the ends are not cut perpendicular to the hole, then when you assemble the parts, it will push the opposite end of the shaft off center in the hole. Just my 2 cents.
