Turning Archive
Re: Jorge, Check for bad coil symptoms
Ha, not only "weak" but it can be dead! Until it cools.
One way you might test the coil if you can get to it - I used to debug overheating electronic components by spraying with freeze spray. If heat was a problem cooling the right part would make the circuit work again. If cooling down the coil makes it run again you maybe you won't have to buy a new one just to test.
(At least some freeze spray is highly flammable so I'd spray then let vapors dissipate before trying to restart.
I don't know where to by freeze spray for electronics these days without a search, but I notice some of the brake cleaner I use seems to come out of the can icy cold. Maybe check Amazon.
I know you can buy medical freeze spray but I imagine it might cost a pound of flesh. :)
