Turning Archive
Re: Goblets
Re: Goblets ()
lyle Jamieson
OK I see it clearly now. Go back and revisit the Kobra system option. It will take all the work and fear of catches. If you are getting catches with the Kobra look at my setup instructions and pretend you got it from me. My system with the Hunter carbide cutter in slicing mode (not scraping) will leave it with no sanding needed. The Kobra should be able to do the same. If you have the laser it will save you a lot of time, also and get your wall thickness uniform. A captured bar will be able to get into the same small sizes, like a goblet, as you can reach with hand held tools.
