Turning Archive
Re: Need help finding.....
Paul Grenier
Check out Wood Turners Wonders for his set up. I plan to purchase the whole system as soon as I'm done with my current supply of 2" and 3" sanding disc's. Many of my sanding stuff is starting to fail after putting on and taking off many, many times. I like Ken's system with a velcro pad for each grit and you just twist off the whole sanding head and twist on the next head with the next grit. The velcro backing pad and the foam should last a whole lot longer than the conventional set up. I've tried some of Ken's new sanding medium and really like it and it's about 1/3 the cost of Abranet which is what I primarily use now.
