Turning Archive
Re: Old Delta tailstock.....
Old Delta tailstock..... ()
jmohnike
If you can remove the tailstock quill and pour break fluid down the shaft let it sit and penitrate you can also use a heat gun to expand the metal and tap it with a brass hammer to help loosen the parts. If this was/is not a self extracting system there would/should be a slot to insert a removal key. When (if) it is removed insert a 3/8 x 1/2 slug prior to reinserting the center. Be sure to clean the inside and remove all the rust.
