Turning Archive
Re: Skew Sharpening with a Belt Sander *PIC*
Jerry Hall
Here is a slide show link to a jig that uses an old portable belt sander:
https://picasaweb.google.com/jerhall95945/BeltSanderSharpening02#5450798336299674690
I made it for a youth turner as a safe and cheap sharpening alternative.
Below is a picture using the setup to sharpen a skew. Of course you don't get a hollow grind so refining the edge with a hone does not give you the two control points for a good job. But it works, and you can use a fine grit belt. Change to course when reshaping or major cleanup is necessary.
Thought of making another for traveling or demos since it is light weight and handy.
