Turning Archive
Re: 2035B headstock ticking noiseResponse To:
Re: 2035B headstock ticking noise () Dick Hines
Aage, check the set screw in the spindle lock. I have had trouble with mine comming loose from time to time. If you can get the spindle lock button out it is an easy fix. If not you can cut a allen wrench off and then you can get to the screw.
The last time mine worked loose I put a drop of CA on the threads and it has not worked loose again.
Messages In This Thread
- 2035B headstock ticking noise
- What worked for me
- Thanks for the suggestions
- Re: 2035B headstock ticking noise *LINK*
- Mines been ticking for two years *NM*
