Hand Tools Archive 2009
There isResponse To:
Re: Which way do you want to taper the hole? () Denis Chénard, Orléans, Ont.
>Don't know if it's used anymore but there's a such a thing as a fox-wedge tenon. Using a special bit the hole is reamed from the inside (like a dovetail), the tenon is kerfed and a wedge is inserted partly. Driving the leg in the hole tighten things up.
Never done it or even seen it done, but I would assume this is a fussy joint to make, which probably explains why it is not common.
DC
Messages In This Thread
- how to taper a blind hole
- thanks to all
- Re: how to taper a blind hole
- I think
- Sounds Painful...
- Which way do you want to taper the hole?
- Re: how to taper a blind hole *LINK*
- thanks to all
