Hand Tools Archive 2009
I wouldn't call it "inadequate"
Denis Chénard, Orléans, Ont.
>There was an article in FWW a while ago about controlling blotching, and quoting from memory, sanding cherry to 400 grit did help a good deal in controlling blotching. I suspect that at this grit level the wood gets burnished as much as it gets sanded.
But this goes against my grain, I prefer planed surfaces.
I don't stain wood as a principle (YMMV), so blotching is less of an issue for me, besides I don't use oil much as a finish.
Using a washcoat does indeed eliminate most blotching. But one rationale behind an oil finish is to pop out the grain. I wonder if anyone has tried using a very diluted coat of clear oil as a first finishing step. Blotching occurs when an area sucks in more oil than the rest. If the oil is thinned a lot, there is not much oil that can get absorbed, yet it should create a barrier for the subsequent coats.
Just a theory...
DC
Messages In This Thread
Pssst! Wanna see spme pretty cherry?
Re: Pssst! Wanna see spme pretty cherry?
yes....
Damn right I do!
Not SC Cherry!
Maloof finish
Re: Not SC Cherry!
And....
Re: Not SC Cherry!
Will someone explain "blotching"?
"blotching" What I was learned...
Liveliness
Exactly Warren!
Re: Exactly Warren!
But, ThomD You ARE a true ge
thanks- "blotch" lovers unite
Seems time for some before and after...
Re: thanks- "blotch" lovers unite *PIC*
Hey Thom, what did you use as a finish on that?
Re: Hey Thom, what did you use as a finish on that
Thanks, What flavor did you use? *NM*
Re: Thanks, What flavor did you use?
Suggestion re cherr
your issue was inadequate surface preparation
Re: your issue was inadequate surface preparation
cherry coloring procedure
I think of finish this way... *PIC*
Nice ! Thanks James...
Re: Nice ! Thanks James... *PIC*
Very Nice !
comments
Re: Will someone explain "blotching"?
good points *NM*
Re: Not SC Cherry!
Re: Not wanting to argue with Bill T.
did I get a good test?
Re: did I get a good test?
Waterlox warning
Jelling in the can...
Re: Waterlox warning
No worries Hank...
depends on what you can apply successfully
But Bill isin't Laquer soliveable...
You're thinking about shellac, Scott
Thanks James, I knew Shellac was...
no
Nice DBG
Indeed! any ideas from whence it came
I thought at the time they would make
