Hand Tools Archive 2009
your issue was inadequate surface preparation
Suggestion re cherr ()
Bill Tindall, E.TN
>I stain most wood and at my level of expertise with planing and scraping I can't control stain take-up with a scraped or planed surface. However, properly sanded that place that stained dark would not have stained dark. I sand till the surface has a uniform luster. Places where there are grain reversals are prone to tearing and even on a micro scale they become stain absorbers. Also, they become sanding dust trappers. Until all this torn partial end grain is removed (and maybe burnished besides) it will trap sanding dust and appear dull. Hence, I sand till these places are the same luster as ever where else. Ditto for end grain edges. Again, properly sanded end grain stains just like the flat edges and faces.
When I finish cherry these grain variations appear as highlights, not blotches.
I expect that planed and scraped surfaces will need to be wash-coated to control "colorant" take up for surfaces with grain variations, whether the colorant is oil or stain. I had to wash coat the mahogany crotch I finished or the end grain portions would have turned almost black with oil. Veneer is nothing but micro-torn grain.
Messages In This Thread
Pssst! Wanna see spme pretty cherry?
Re: Pssst! Wanna see spme pretty cherry?
yes....
Damn right I do!
Not SC Cherry!
Maloof finish
Re: Not SC Cherry!
And....
Re: Not SC Cherry!
Will someone explain "blotching"?
"blotching" What I was learned...
Liveliness
Exactly Warren!
Re: Exactly Warren!
But, ThomD You ARE a true ge
thanks- "blotch" lovers unite
Seems time for some before and after...
Re: thanks- "blotch" lovers unite *PIC*
Hey Thom, what did you use as a finish on that?
Re: Hey Thom, what did you use as a finish on that
Thanks, What flavor did you use? *NM*
Re: Thanks, What flavor did you use?
Suggestion re cherr
Re: your issue was inadequate surface preparation
cherry coloring procedure
I think of finish this way... *PIC*
Nice ! Thanks James...
Re: Nice ! Thanks James... *PIC*
Very Nice !
comments
I wouldn't call it "inadequate"
Re: Will someone explain "blotching"?
good points *NM*
Re: Not SC Cherry!
Re: Not wanting to argue with Bill T.
did I get a good test?
Re: did I get a good test?
Waterlox warning
Jelling in the can...
Re: Waterlox warning
No worries Hank...
depends on what you can apply successfully
But Bill isin't Laquer soliveable...
You're thinking about shellac, Scott
Thanks James, I knew Shellac was...
no
Nice DBG
Indeed! any ideas from whence it came
I thought at the time they would make
