Hand Tools Archive 2009
Re: thanks- "blotch" lovers unite *PIC*
ThomD
>I was just finishing up this spinning wheel part in maple, and it has a difinite blotch on it, so it isn't just cherry. It is a piece with very minimal curl, and there is this dark patch. I took a photo of it, but it doesn't show up. The left foot piece in the foreground, but it isn't visible.
Messages In This Thread
Pssst! Wanna see spme pretty cherry?
Re: Pssst! Wanna see spme pretty cherry?
yes....
Damn right I do!
Not SC Cherry!
Maloof finish
Re: Not SC Cherry!
And....
Re: Not SC Cherry!
Will someone explain "blotching"?
"blotching" What I was learned...
Liveliness
Exactly Warren!
Re: Exactly Warren!
But, ThomD You ARE a true ge
Seems time for some before and after...
Hey Thom, what did you use as a finish on that?
Re: Hey Thom, what did you use as a finish on that
Thanks, What flavor did you use? *NM*
Re: Thanks, What flavor did you use?
Suggestion re cherr
your issue was inadequate surface preparation
Re: your issue was inadequate surface preparation
cherry coloring procedure
I think of finish this way... *PIC*
Nice ! Thanks James...
Re: Nice ! Thanks James... *PIC*
Very Nice !
comments
I wouldn't call it "inadequate"
Re: Will someone explain "blotching"?
good points *NM*
Re: Not SC Cherry!
Re: Not wanting to argue with Bill T.
did I get a good test?
Re: did I get a good test?
Waterlox warning
Jelling in the can...
Re: Waterlox warning
No worries Hank...
depends on what you can apply successfully
But Bill isin't Laquer soliveable...
You're thinking about shellac, Scott
Thanks James, I knew Shellac was...
no
Nice DBG
Indeed! any ideas from whence it came
I thought at the time they would make
