Hand Tools Archive 2009
Suggestion re cherr
Wiley Horne--So. Calif.
>Hi Bill and all,
I would like to agree with you and Warren, with one caveat. I think I know exactly what you're talking about. I am looking at a cherry table top right now, one that has some curl figure to it (though not outrageous like Hank's). It has a subtle mottling effect that brings out the figure, and is just beautiful. There is an overall rolling, sort of wide quilted effect. I began the finish of this top with one coat of 1/2 pound dewaxed blonde shellac, as a partial filler.
Now. Years ago, when my finish for everything was Minwax oil stain, I would sometimes have a cherry board, that when the oil hit it, it would be clear over most of the board, but would have one large patch of 'blotch'--maybe a patch of grain runout. Now that looked like hell, because it did not give that rolling effect that enhances the grain and figure--it simply looked like a stain, like something had been spilled on the wood. And it is deep--would not come out.
So. Hank's issue is to know what he has before he commits to a finish. I would suggest take two large enough pieces of raw planed scrap, and use a thin shellac coat on one, and oil on the other, and see whether he likes more contrast (oil finish) between dark and light in the curl figure, or a more subtle contrast (thinned shellac). If he wants a very clear even finish, he could try a 1-lb or higher cut. My point is, it is controllable.
I'm not sure what the magazine writers are talking about, but there is such a thing as random stain-looking blotch, which is not the same as as the natural rolling figure I think you are talking about.
Wiley
Messages In This Thread
Pssst! Wanna see spme pretty cherry?
Re: Pssst! Wanna see spme pretty cherry?
yes....
Damn right I do!
Not SC Cherry!
Maloof finish
Re: Not SC Cherry!
And....
Re: Not SC Cherry!
Will someone explain "blotching"?
"blotching" What I was learned...
Liveliness
Exactly Warren!
Re: Exactly Warren!
But, ThomD You ARE a true ge
thanks- "blotch" lovers unite
Seems time for some before and after...
Re: thanks- "blotch" lovers unite *PIC*
Hey Thom, what did you use as a finish on that?
Re: Hey Thom, what did you use as a finish on that
Thanks, What flavor did you use? *NM*
Re: Thanks, What flavor did you use?
Suggestion re cherr
your issue was inadequate surface preparation
Re: your issue was inadequate surface preparation
cherry coloring procedure
I think of finish this way... *PIC*
Nice ! Thanks James...
Re: Nice ! Thanks James... *PIC*
Very Nice !
comments
I wouldn't call it "inadequate"
Re: Will someone explain "blotching"?
good points *NM*
Re: Not SC Cherry!
Re: Not wanting to argue with Bill T.
did I get a good test?
Re: did I get a good test?
Waterlox warning
Jelling in the can...
Re: Waterlox warning
No worries Hank...
depends on what you can apply successfully
But Bill isin't Laquer soliveable...
You're thinking about shellac, Scott
Thanks James, I knew Shellac was...
no
Nice DBG
Indeed! any ideas from whence it came
I thought at the time they would make
