Hand Tools Archive 2008
Re: Tales of hide vs white glue for veneering *LINK*
Paul Kierstead
>I've done some hammer veneering, and done some vac bagging. I'm not gonna tell ya that hammer veneering is the be-all end-all; it certainly isn't, and I own a vacupress set-up that I love. But, your two cases of woe sound like people (the teacher and the pro, not your friend) who haven't done it recently or haven't done it much.
- Corners are always one of the hardest bits IME in hammer veneering. But, using an Iron after the fact makes it quite easy. If the demonstrator didn't know enough to apply an iron, I have to wonder how much he has done it in the last 15 years
- The teacher trying for a first crack to do a burl was very foolish. Even in vacuum pressing, burls can create a lot of problems with bleed through, adhesion, etc. (though clearly don't always cause a lot of problems). Trying it as your learning project for hammer veneering seems pretty much destined to failure. It is definitely a skill which needs to be built up.
All that said, I still use a bag particularly for large surfaces or repetitive work. Hammer veneering is great for quick stuff (no need to make up cauls, etc) and odd things which won't go in a bag well (like veneering the face of a drawer after it has been assembled....)
Now if you want a good disaster, read what happened when I bit off more then I could chew doing a hammer veneering.... (I've since both got better at hammer veneering and got a vacupress system)
Messages In This Thread
Tales of hide vs white glue for veneering *PIC*
Can HHG be used with a vacuum . . .
Re: Can HHG be used with a vacuum . . .
I said it Could be one...
Re: Tales of hide vs white glue for veneering *PIC*
Seconding Victor's request! And also,
Wow. From what I can see...
Re: Wow. From what I can see... *PIC*
Re: Hey is that...
Re: Tales and now the truth.
very hard to do
Re: very hard to do
Re: very hard to do
Again... who's here?
Veneering by Professionals (long and boring)
Re: the steep part of the learning curve
Re: very hard to do
Re: very hard to do
thank you
How do you "bag" a 4'X24' piece? *NM*
Re: How do you "bag" a 4'X24' piece?
Get a really long bag.
Re: Get a really long bag.
Is there a problem using vacuum cleaners? *NM*
Re: Is there a problem using vacuum cleaners?
Thanks, all.
Re: Thanks, all.
Re: Thanks, all.
Re: Thanks, all.
I see, bummer. And urea doesn't help enough? *NM*
Re: I see, bummer. And urea doesn't help enough?
Just what I was thinking, Wilbur. *NM*
Repairing veneer
PS
Re: PS
