Hand Tools Archive 2008
Inshave or Scorp
Head scratcher ()
>should work, also a handled box plane, the type used to remove lables from packing boxes. Also there is a brass pull shave that bowl and spoon makers use, should also work.
You probably need something like a heavy radius blade on a scrub plane.
Be careful when you lick your tools when you are done, the blade is sharp.
Stephen
