Hand Tools Archive 2007
Re: Fine Shavings
Re: Fine Shavings ()
Warren in Lancaster, Pa
>Thanks for responding, James. I was reacting to your mention of taking very thin shavings on some very curly maple. In this case, one can avoid tearout with extremely fine shavings no matter how the plane is set up. On the other hand a scrub plane can often leave a curly surface worse than when it started. You can plane it very nicely with a fine setting and a tight mouth, but at the cost of many passes. I think a double iron plane is more efficient here.
Messages In This Thread
chip breaker/cap iron or not?
Re: chip breaker/cap iron or not?
You guys are awesome
thank you all and 1 more thing
Re: thank you all and 1 more thing
We've got a few... *LINK*
Double Iron
And let's not forget HNT Gordon planes *PIC*
Some thoughts but no new tests
Re: Some thoughts but no new tests
Update your WoodCentral email
Clarification
Re: Clarification
Fine Shavings
Re: Fine Shavings
Re: Fine Shavings
Re: Fine Shavings
Fine shavings and thick shavings
Re: Fine shavings and thick shavings
No. 46 degrees is the steepest
Re: No. 46 degrees is the steepest
Re: 46 degrees is the steepest
How to look at the post you are responding to
Re: How to look at the post you are responding to
Thanks
Oops, my bad, found the prefs. *NM*
Re: Fine Shavings
Re: Fine Shavings
Re: Fine Shavings
Re: Fine Shavings
Chris, I have a question for you,
Re: Fine Shavings
Re: Fine Shavings
I don't think so *LINK*
Huh?
Re: Huh?
Really Huh?
Re: Really Huh?
Re: Really Huh?
Question and correction.
I'd really like to hear Larry's/James' response. *NM*
Re: I'd really like to hear Larry's/James' respons
Facts
recanting?
Re: Facts
Tread carefully
Re: Tread carefully
Re: Tread carefully
cap iron use- please help
sawing planes in half
that could work- thanks! *NM*
Re: cap iron use- please help
Re: chip breaker/cap iron or not? *PIC*
Apologies Wayne...
Re: Apologies Wayne...
