Hand Tools Archive 2007
Re: Ten minutes "moves" hollow 3 mm
Miles
>Tapping out could presumably leave some additional tensile stress on the lower surface of the chisel, where the steel has been distorted by the blows to bring it down to the target level. It is probably only a small distortion, but if the steel is hard, the stress associated may be large. This is the opposite of what happens in prestressed beams etc where a stress is engineered in to oppose the normal load in use.
I would wonder about the risk of promoting edge fracture when tapping out, as the resulting stresses in the lower surface should be tending to promote cracking at any scratch or grain boundary.
There's a reason why annealing is important after forging (or hardening) - I'm not a metallurgist, though, and it would be interesting to see if any here can comment.
I'd go with grinding, myself, to get that hollow moved back. The comments above about tapping helping to sell more chisels does rather suggest that it is a risky approach, and I cannot see any significant advantage.
Miles
Messages In This Thread
Sharpening Japanese chisels - the irritating part
Comments and observations
Re: Comments and observations
Wha...Huh?
Re: Wha...Huh?
Ahh, got it...
Re: Ahh, got it...
Waxing philosophical, Pam?
Or waning.
Hmmm... seems things around here.
What, precisely, was heated, Scott? *NM*
Seems to me that this time of the years...
There's a reason...
Re: There's a reason...
Unfortunately, it's been made so
Re: Unfortunately, it's been made so
I'm in complete agreement Bill *NM*
ZOOM!
I like your way of thinking
Re: Sharpening Japanese chisels - the irritating p
Re: Paring chisels for best edge
Tomohito-san's sharpening guide
Enough said?
Re: Enough said?
Thanks, Vijay. *NM*
Re: Enough said?
Re: Enough said?
Re: Enough said?
I tell you this: Nobody knows it all, NOBODY! *NM*
Re: Abusing furniture
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said? *LINK*
Hey my chisel smells like Crest!
Re: Hey my chisel smells like Crest!
Crest or Toms...
There and Back Again
Re: There and Back Again
I put a hollow grind on a Japanese blade
Re: I put a hollow grind on a Japanese blade
Re: hollow grind - accelerate wear
Not really
Re: Not really
Re: Not really
I disagree
:-) *NM*
Re: Sharpening Japanese chisels - lifespan?
Dave, thank you so much
Dave, thank you very much;-) NM *NM*
:) *NM*
Re: Sharpening Japanese chisels - lifespan? *PIC*
Is that those cheap chisels...
Question, Dave
Re: Question, Dave
Matte vs. Mirror Finish
Re: Matte vs. Mirror Finish
Possible answer to paradox
A couple more variables...
Yet another thought...
Re: Chemical polishing
I hope others are reading this. Very interesting *NM*
I hate to admit it...
Re: A couple more variables...
Oops, should be "analogous" *NM*
Re: Possible answer to paradox
Not a contradiction
Not buying that
Not the theory
Re: Not the theory
Re: Not the theory
Re: Not the theory
Oh yeah, done on Matsumura chisels *NM*
Maybe you should just unplunge yourself
Country boy sez...
Re: Country boy sez...
