Hand Tools Archive 2007
Re: Matte vs. Mirror Finish
Denis Chénard, Orléans, Ont.
>"It goes both ways. If man-made abrasives are better, and they produce a better edge while leaving the bevel "shiny", then there should be a scientific explanation as to why this is the case. Anything less doesn't cut the mustard IMHO. (That physics Ph.D. makes me cranky sometimes.)"
Granted. The hypothesis here that man-made abrasives used in the stones are of uniform (or close to) size, thus they abrade the steel in a consistent manner. Go fine enough, and the surface becomes so flat as to reflect light. If the back and bevel can become that flat, then their junction should be as sharp as possible.
OTOH, the more dispersed particulate size of a natural stone creates a random scratch pattern, which disperses light because of the less flat surface. Again these scratches on both bevel and back, when they meet at the edge, should make for a less sharp edge. Frank says that his observations contradict this.
The only way that I could explain this paradox it that the bevel and back, in contact with the stone, do indeed produce a rougher surface. But the slurry, being made of broken down particles, becomes finer and finer as we go, and it would be the slurry that does refine the edge. The bevel (or back), being in contact with new particles from the stone, can't get shiny because it's in contact with fresh particles of "random" size.
Does that make kind of sense?
DC
No Ph.D (dropped out at the thesis stage), but I did start in physics in university (long story).
Messages In This Thread
Sharpening Japanese chisels - the irritating part
Comments and observations
Re: Comments and observations
Wha...Huh?
Re: Wha...Huh?
Ahh, got it...
Re: Ahh, got it...
Waxing philosophical, Pam?
Or waning.
Hmmm... seems things around here.
What, precisely, was heated, Scott? *NM*
Seems to me that this time of the years...
There's a reason...
Re: There's a reason...
Unfortunately, it's been made so
Re: Unfortunately, it's been made so
I'm in complete agreement Bill *NM*
ZOOM!
I like your way of thinking
Re: Sharpening Japanese chisels - the irritating p
Re: Paring chisels for best edge
Tomohito-san's sharpening guide
Enough said?
Re: Enough said?
Thanks, Vijay. *NM*
Re: Enough said?
Re: Enough said?
Re: Enough said?
I tell you this: Nobody knows it all, NOBODY! *NM*
Re: Abusing furniture
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said? *LINK*
Hey my chisel smells like Crest!
Re: Hey my chisel smells like Crest!
Crest or Toms...
There and Back Again
Re: There and Back Again
I put a hollow grind on a Japanese blade
Re: I put a hollow grind on a Japanese blade
Re: hollow grind - accelerate wear
Not really
Re: Not really
Re: Not really
I disagree
:-) *NM*
Re: Sharpening Japanese chisels - lifespan?
Ten minutes "moves" hollow 3 mm
Re: Ten minutes "moves" hollow 3 mm
Dave, thank you so much
Dave, thank you very much;-) NM *NM*
:) *NM*
Re: Sharpening Japanese chisels - lifespan? *PIC*
Is that those cheap chisels...
Question, Dave
Re: Question, Dave
Possible answer to paradox
A couple more variables...
Yet another thought...
Re: Chemical polishing
I hope others are reading this. Very interesting *NM*
I hate to admit it...
Re: A couple more variables...
Oops, should be "analogous" *NM*
Re: Possible answer to paradox
Not a contradiction
Not buying that
Not the theory
Re: Not the theory
Re: Not the theory
Re: Not the theory
Oh yeah, done on Matsumura chisels *NM*
Maybe you should just unplunge yourself
Country boy sez...
Re: Country boy sez...
