Hand Tools Archive 2007
Re: Not really
Not really ()
thomd
>I don't agree it's of little concern that there is a hollow. It may not be of concern in specific case. However it's a whole other story.
On the accelerating wear thing I think it's the purpose and the result. In practical terms the way the grinding proceeds is that one cuts until there is a burr from a 60 grit wheel or thereabouts, this usually produces quite a significant loss in chisel length. That's what I would call the result. But surely that's what we want, for the sharpening to be fast and effective. It's a very good way to proceed with a HSS cutter for a machine tool where the blank is perhaps 2-6 bucks. We are working a material in the case of Japanese chisels that is somewhere in the range of silver-gold by weight.
The secondary objective is often getting the hollow grind so it is easier to read the subsequent hand sharpening, and faster to sharpen. Cutting rate is relative to the PSI on the surface, and the steel cuts faster by hand when there are only two lines worth of to remove. That's the stated objective, faster sharpening. And again it means increased wear.
If you are suggesting the purpose to grinding is to remove less material than on finishing stones, that's quite a sales pitch.
Messages In This Thread
Sharpening Japanese chisels - the irritating part
Comments and observations
Re: Comments and observations
Wha...Huh?
Re: Wha...Huh?
Ahh, got it...
Re: Ahh, got it...
Waxing philosophical, Pam?
Or waning.
Hmmm... seems things around here.
What, precisely, was heated, Scott? *NM*
Seems to me that this time of the years...
There's a reason...
Re: There's a reason...
Unfortunately, it's been made so
Re: Unfortunately, it's been made so
I'm in complete agreement Bill *NM*
ZOOM!
I like your way of thinking
Re: Sharpening Japanese chisels - the irritating p
Re: Paring chisels for best edge
Tomohito-san's sharpening guide
Enough said?
Re: Enough said?
Thanks, Vijay. *NM*
Re: Enough said?
Re: Enough said?
Re: Enough said?
I tell you this: Nobody knows it all, NOBODY! *NM*
Re: Abusing furniture
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said?
Re: Enough said? *LINK*
Hey my chisel smells like Crest!
Re: Hey my chisel smells like Crest!
Crest or Toms...
There and Back Again
Re: There and Back Again
I put a hollow grind on a Japanese blade
Re: I put a hollow grind on a Japanese blade
Re: hollow grind - accelerate wear
Not really
Re: Not really
Re: Not really
I disagree
:-) *NM*
Re: Sharpening Japanese chisels - lifespan?
Ten minutes "moves" hollow 3 mm
Re: Ten minutes "moves" hollow 3 mm
Dave, thank you so much
Dave, thank you very much;-) NM *NM*
:) *NM*
Re: Sharpening Japanese chisels - lifespan? *PIC*
Is that those cheap chisels...
Question, Dave
Re: Question, Dave
Matte vs. Mirror Finish
Re: Matte vs. Mirror Finish
Possible answer to paradox
A couple more variables...
Yet another thought...
Re: Chemical polishing
I hope others are reading this. Very interesting *NM*
I hate to admit it...
Re: A couple more variables...
Oops, should be "analogous" *NM*
Re: Possible answer to paradox
Not a contradiction
Not buying that
Not the theory
Re: Not the theory
Re: Not the theory
Re: Not the theory
Oh yeah, done on Matsumura chisels *NM*
Maybe you should just unplunge yourself
Country boy sez...
Re: Country boy sez...
