David Weaver
tap tap through the knot or some other kind of remediation is probably best for the chisel.
But it's a good test.
At some point, going with Cliff Stamps language, the failure that would have occurred is now pushed past the initial bevel. But that's part of the design.
And with a less strong bevel, the damage goes there, anyway.
This is a constant problem with overhard japanese chisels (losing corners), but it occurs in regular wood. I bought a super hard set of ouchi 1 (old guy, his son took over since then) chisels from MJD - someone had bought them long ago, and the set of 12 or 14 went for the princely sum of $485 on a straight up auction on MJD. This is actually a pretty low price. They hadn't been used.
They had very thin bevels on them, someone probably just cut the bevel on a wet wheel and may or may not have done some aesthetic work to the bevel to bring out the transition between hard and soft, and then they were lacquered.
Being pleased to have such a nice chisel set at that price, I tried them with a light hand mortising waste from a plane. The bevels crumbled.
I gave them a steeper bevel at the tip, proceeded to mortise without a heavy hand (but steadily) and the corners left the scene on them again. I sold stones on etsy at the time. When a set is that nice, i'm not inclined to take them apart and temper them, but they needed it. Too hard to sharpen at any reasonable pace on a strong cutting suita, and ice on one of my stronger washitas - both indications of excessive hardness.
Messages In This Thread
- Unicorned Chisel meets a challenge
- Re: Unicorned Chisel meets a challenge
