you're still failing...
Re: blogger grind *PIC* ()
David Weaver
..to address the chisels at are out there from I&H sorby.
you've had one of these :|
This is a yes or no question:
* the chisel (two of them) has grind marks that go end to end and the marks on the small bevel match the rest of the chisel in terms of fineness, and there is no fine edge on the chisel and no sign of damage (it's not blunted off)
* there is no sign of honing on the bottom of the chisel, the mill marks at the bolster are identical from end to end (very finely finished, but obviously by a wheel as all of the marks progress parallel to the direction of the chisel
* the curvature on the tops of the chisels have the same mill marks on them, no evidence of being stoned or ground with something else
* tooltique has chisels that look identical (you've dismissed them because the guy does minimal restoration)
* bode's listings of IH sorby have this rounded top unless they're short (those still have a rounded top, but it's sloppily refreshed in some cases)
* all of the chisels shown pictured anywhere with this roundover have a similar look
This chisel was modified by later users, including some who never used the chisels or honed any other part, and all of them match (all of the different users made an identical looking roundover) - yes or no.
Now, let's do another survey of likelihood -if this was done to the IH sorby chisels, I should be able to find neatly redone marples chisels and a sample of all of them from a similar time frame should show that most of the marples chisels that are full length should be rounded over.
There's no unknown variable that would make them different.
IH sorby (you have to parse the I sorby and R sorby out, different maker):
https://www.google.com/search?q=IH+sorby+pigsticker&tbm=isch&ved=2ahUKEwjQvPDu5tTqAhUO0awKHcEUBmMQ2-cCegQIABAA&oq=IH+sorby+pigsticker&gs_lcp=CgNpbWcQAzIECCMQJ1DzDljNFGDJFWgAcAB4AIABZYgB4gaSAQM4LjKYAQCgAQGqAQtnd3Mtd2l6LWltZ8ABAQ&sclient=img&ei=y94RX5CrPI6iswXBqZiYBg&bih=969&biw=1920#imgrc=Jok-GiD0HEElJM
Marples:
https://www.google.com/search?q=marples+pigsticker&sxsrf=ALeKk00MkBQJmPTkhgRJY9nDRoNzkFrWrQ:1595006620298&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjDnpHY5tTqAhWFB80KHfGgD_oQ_AUoAnoECA0QBA&biw=1920&bih=969#imgrc=GNGhjsA0n5fn_M
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Separate on the IH sorby chisels..
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from various compounds *PIC*
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Re: Other Compounds *PIC*
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Factory ground *PIC*
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
