will do...
David Weaver
i can share the part number of my favorite wheel, but I have probably over the years only tried 6 or so. No guarantee that a different type doesn't work better (more stitches to the edge, different material, etc).
Ryobi: A04BG06
there's differences in the number of plies, the number of stitches, where the stitches are, etc. No great reason to become an expert to save $10 (but I don't follow my own advice on that, i'll admit).
Those buff wheels show up unused from time to time, but I'm guessing based on the color of the packaging and the widespread availability of a different set of ryobi buffs that these are just old stock trickling out from oddball sellers (people who buy return lots, etc).
I see the sentiment is going toward finer here, but I'm inclined to stick with the yellow stuff because I'm used to it. The yellow stuff is 5 micron yellow jackson lea bar from mcmaster carr (calcined alumina). I think anything of reasonable quality will work well. I have no idea how many factors could affect my results (e.g., winston's bevels look a bit shorter and steeper - is that affected by the compound cutting power and the buff speed, both, etc?).
Sharpness is absurd even with yellow, and a complete result is almost guaranteed because the buffer doesn't just finish the edge that's there, it removes some of it and replaces the front side.
https://www.mcmaster.com/buffing-bars (listed as yellow in the top section under "cutting/coloring" category)
Will report back if experience with other bars is better, though. I think with a high speed buff and a wheel with a little bit of back bone, much of the compounds should be interchangeable.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Separate on the IH sorby chisels..
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from various compounds *PIC*
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Re: Other Compounds *PIC*
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Factory ground *PIC*
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
