Re: Other Compounds *PIC*
Other Compounds ()
Winston
> All have been good and even, but I haven't gotten every type. McMaster has a 0.5 micron rouge colored bar and a green bar that's 1 micron. I have both coming today to see how fine they are. If the green bar is actually 1 micron, it will be finer than the microfine compound sold to woodworkers (used to be sold as 0.5 microns, but the manufacturer says particles up to 6 are present in it. It works well, but no great reason to pay $11-$14 for 6 ounces when a 2 1/2 or 3 pound bar from industrial or buffing suppliers is more or less the same price.
That must be the same green bar I got from from McMaster. I can't say how fine the particles actually are though. I wouldn't have expected 1 micron scratches to be as easily visible as the scratches I actually saw from the green compound (using the stick directly, without the buffing wheel), but it's hard to say for sure how deep those scratches were. And maybe there were clumps of abrasives, making for deeper scratches? At any rate, the scratches with the same compound on a buffing wheel were much smaller.
I did a little Googling and poking around on the Osborn/JacksonLea web site, and what do you know, the MSDS sheets say that the green (supposedly chrome oxide) and red (supposedly iron oxide) compounds have a lot of aluminum oxide, like 10x as much as the stuff they're advertised as.
Green: https://www.osborn.com/media/msds/pdf/47012.PDF
Red: https://www.osborn.com/media/msds/pdf/47013.PDF
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Separate on the IH sorby chisels..
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from various compounds *PIC*
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Factory ground *PIC*
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
