Winston
> You can get the effective cutting angle, before and/or after, by running the chisel bevel down across your benchtop, and check the angle where it first begins to dig in. Do this beside a vertical surface like a block of 2x4, mark the angle where the chisel begins to bite, and check that angle with your own protractor.
I gave it a try. On a very smooth planed piece of white pine, I got anywhere between about 35 and 42 degrees. It's hard to get a consistent reading. The angle where it first digs in is sensitive to amount of downward pressure. If the chisel gets rotated (along the long axis) a bit in either direction, the corners dig in, and then if I try to stabilize it by putting a little bit of pressure near the tip (as if sharpening freehand), that makes it want to dig in at a lower angle than it would otherwise. As I raise the angle, there's also a range of angles where it stutters but doesn't quite catch. So... in short, in order to get a consistent value, I think the variables would have to be controlled much better than I'm able to do.
Messages In This Thread
- Sharpening and buffing progression pictures *PIC*
- Separate on the IH sorby chisels..
- Comparative Profile Pictures
- Profile pictures *PIC*
- Thoughts on the data
- Angle near the edge *PIC*
- Re: Angle near the edge
- Capturing the Unicorn Profile
- Calcined alumina *PIC*
- Scratches from various compounds *PIC*
- Scratches from more compounds; buff vs stick *PIC*
- Other Compounds
- Re: Other Compounds *PIC*
- great experiments
- Re: Scratches from more compounds; buff vs stick
- The white stuff is...
- Re: The white stuff is...
- various compounds - difficult to judge
- Re: various compounds - difficult to judge
- looking forward to...
- Further Observations
- Thank you for experimenting
- these results will require some study
- Other Compounds
- David & Winston
- Thinking about establishing the Unicorn profile
- Re: Sharpening and buffing progression pictures
