Re: Amen, ReverendResponse To:
Amen, Reverend () Winston
> A buffer and wheel cost under $100 and should last indefinitely.
Or even less! I initially spent $10 on the buffing kit for my drill, which is not only cheap, but also doesn't require any additional bench space.
Now, if this can be made to work with plane blades, then it would greatly simply my sharpening setup. As I mentioned before, I got a very, very smooth surface with a buffed plane blade, but I didn't test it to see how much wood it could plane before having clearance issues. Even if that's the same or slightly worse than my normal sharpening, that's still very good, considering how simple and easy it is.
Messages In This Thread
- Sharpening and buffing progression pictures *PIC*
- Separate on the IH sorby chisels..
- Comparative Profile Pictures
- Profile pictures *PIC*
- Thoughts on the data
- Angle near the edge *PIC*
- Capturing the Unicorn Profile
- Calcined alumina *PIC*
- Scratches from various compounds *PIC*
- Scratches from more compounds; buff vs stick *PIC*
- Other Compounds
- Re: Other Compounds *PIC*
- great experiments
- Re: Scratches from more compounds; buff vs stick
- The white stuff is...
- Re: The white stuff is...
- various compounds - difficult to judge
- Re: various compounds - difficult to judge
- looking forward to...
- Further Observations
- Thank you for experimenting
- these results will require some study
- Other Compounds
- David & Winston
- Thinking about establishing the Unicorn profile
- Re: Sharpening and buffing progression pictures
