I don't agree with limitation of your premise
Chipping and rolling come from shear and bending forces: prying, twisting, scraping, digging.
These dulling mechanisms certainly could result from the forces you enumerate but they also result from impact on an acute edge that is not sufficiently tough or hard enough to resist these forces. For any given steel just start lowering the bevel angle and at some point you are going to see dulling by either chipping or folding at the very tip no matter how perfect the striking force. Or alternatively, bash the chisel with ever increasing force and get the same result.
I will not deny that technique can influence the longevity of a chisel tip but the steel and its heat treatment also has a profound effect on what bevel angle the chisel performs satisfactorily. Now Weaver has shown that the edge profile may be as significant a variable as the steel properties.
We need to not loose sight of Weaver's discovery by getting distracted by technique. A 30 second addition to a chisel edge preparation turned a $10 chisel into one that performed as well as any I have on the bench, including a $70 LV. If this experience can be replicated by others it will be as significant as the rediscovery of the close set cap iron. Our role should be to encourage others to try it to see how broadly the benefit applies.
The goal is longer edge life. If someone gets it with sloppy technique and a more expensive steel it is the same result as getting longer edge life with better technique. Now we have a new variable to explore to reach this goal.
Messages In This Thread
Weaver chisel grind *PIC*
Some quick tests (lots of pictures) *PIC*
Some chisel pictures *PIC*
Re: Some chisel pictures
Re: Some chisel pictures *PIC*
astonished by picture quality *NM*
excellent pictures!
Another test *PIC*
Re: Another test
question
Re: question *PIC*
Re: question
could be a database issue...
Second try for picture *PIC*
yellow pine *NM*
Those pictures..
Nice piece of work
Re: Nice piece of work
Light source?
Re: Light source?
stitches.....
I've made a video.....
video...not for the meek...
It's a very funny video
comments on the two pictures.....
bevel width
It's the scale that escapes me
Re: It's the scale that escapes me
Looking forward to it, thanks! *NM*
More on the Weaver Bevel
Re: More on the Weaver Bevel
the premise is different in this case
You nailed it
This is hilarious
Jim - here's your guy
Well that escalated quickly.
Moving the needle
Re: Moving the needle *LINK*
Thanks for the memories *PIC*
Absolutely *LINK*
Positioning *LINK*
Where to find unhndled Narex chisels? *NM*
Taylor Tool Works
narex and their hardening....
how I achieved the Weaver Bever
Weaver Bevel
Further defining the Weaver Bevel
perception of penetration?
solving a problem, not creating one...
Re: solving a problem, not creating one...
BTW
rolling over edges....
On secrets, incantations and open source
Weaver grind—how is convexity added?
Marc Adams
Could've been felt...
Re: Weaver grind—how is convexity added?
The world is upside down :)
I took a nine day Sellers course
Re: I took a nine day Sellers course
it makes sense
How about making a video?
Period costume?
Re: How about making a video?
Trying things out
Re: Trying things out
failed to figure things out...
variations on the already done...
thoughts *PIC*
Re: Weaver chisel grind
making peculiar names
