rolling over edges....
BTW ()
David Weaver
..the first few times I used buffers or powered leather wheels, I rolled edges over and concluded that I don't get it or it wasn't for me.
I use an incannel gouge a lot on guitars (for bulk work) and now lots of other things where removing bulk. I got stuck using it twice on the cabinet that I posted because I had in-situ waste that needed removing and for whatever reason, an incannel gouge goes through waste a lot easier than a chisel.
But using them heavily means sharpening them regularly and somehow the deburring wheel and buff turned out to be great.
Your mention of a carver makes a lot of sense - you can keep the tools relatively shallow if you like that geometry and then just buzz the tip subtly and it will hold up well.
I'm sure it's been done zillions of times. No idea is really truly original, even when this is even at that, only a slight variation on others' ideas (you could say that it's much like the three bevel system that charlesworth advocates, because other than the incannel gouge, I'm refershing a secondary bevel each time and then a tertiary bit of edge (rounding instead of a bevel) and when the secondary bevel gets large, you chase the tertiary.
I'll be using this method on more carving chisels now (than just the incannel gouges, but it's nice to use those. I have some already, but then a benefit auction on here generously offered by wiley has made me very patternmaker gouge rich).
Messages In This Thread
Weaver chisel grind *PIC*
Some quick tests (lots of pictures) *PIC*
Some chisel pictures *PIC*
Re: Some chisel pictures
Re: Some chisel pictures *PIC*
astonished by picture quality *NM*
excellent pictures!
Another test *PIC*
Re: Another test
question
Re: question *PIC*
Re: question
could be a database issue...
Second try for picture *PIC*
yellow pine *NM*
Those pictures..
Nice piece of work
Re: Nice piece of work
Light source?
Re: Light source?
stitches.....
I've made a video.....
video...not for the meek...
It's a very funny video
comments on the two pictures.....
bevel width
It's the scale that escapes me
Re: It's the scale that escapes me
Looking forward to it, thanks! *NM*
More on the Weaver Bevel
Re: More on the Weaver Bevel
the premise is different in this case
I don't agree with limitation of your premise
You nailed it
This is hilarious
Jim - here's your guy
Well that escalated quickly.
Moving the needle
Re: Moving the needle *LINK*
Thanks for the memories *PIC*
Absolutely *LINK*
Positioning *LINK*
Where to find unhndled Narex chisels? *NM*
Taylor Tool Works
narex and their hardening....
how I achieved the Weaver Bever
Weaver Bevel
Further defining the Weaver Bevel
perception of penetration?
solving a problem, not creating one...
Re: solving a problem, not creating one...
BTW
On secrets, incantations and open source
Weaver grind—how is convexity added?
Marc Adams
Could've been felt...
Re: Weaver grind—how is convexity added?
The world is upside down :)
I took a nine day Sellers course
Re: I took a nine day Sellers course
it makes sense
How about making a video?
Period costume?
Re: How about making a video?
Trying things out
Re: Trying things out
failed to figure things out...
variations on the already done...
thoughts *PIC*
Re: Weaver chisel grind
making peculiar names
