perception of penetration?
David Weaver
Only wiley's prodding a few months ago forced me to measure my primary bevel (grinder rest being set at 90 degrees, and then freehanding from there, I have no clue and have just come to the shallower primary out of laziness).
The edge holds up better on my chisels than 28 or 30 degrees flat primary did, but with a very shallow primary, there is less resistance from the cut. Enough less that it's easy to take something like a harbor freight chisel and do the same cut that will neptune showed with his very long primary chisel.
I cut all of the shoulders to the line (I have always done them previously malleting) and none were chased appreciably low (as you're aware, if you use a more blunt edge, even paring with a narrow chisel, the marked line will get chased back and perhaps unevenly. not a lot, but it's annoying).
The harbor freight chisels are the same thing that aldi markets. They're tolerable. They are probably in the ballpark of robt. sorby chisels, but not nearly as pretty.
Somewhere in the past, I did something similar on one of the newer buck chisels that I ground the corners off of to go straight in to the end on half blinds, and then liked that chisel, too, better than the purpose made skews that I had, so I sold those.
...forgetting the main question here, though. I never noticed a significant increase in resistance other than the first trials, like mortising cocobolo in the smoother I've showed pictures of. I made a stanley fairly blunt and it held up well. When you're mortising a plane, the bevel gets to a cutoff point in cocobolo where it gets steep enough that it will shoot the chips out of the mortise instead of laying them over. I don't usually do that. Other than that instance, never noticed the extra resistance. The fact that the edge stays ideal through work would suggest less average resistance, anyway, even if initial was a tiny bit more.
What did you notice in terms of cut resistance?
Messages In This Thread
Weaver chisel grind *PIC*
Some quick tests (lots of pictures) *PIC*
Some chisel pictures *PIC*
Re: Some chisel pictures
Re: Some chisel pictures *PIC*
astonished by picture quality *NM*
excellent pictures!
Another test *PIC*
Re: Another test
question
Re: question *PIC*
Re: question
could be a database issue...
Second try for picture *PIC*
yellow pine *NM*
Those pictures..
Nice piece of work
Re: Nice piece of work
Light source?
Re: Light source?
stitches.....
I've made a video.....
video...not for the meek...
It's a very funny video
comments on the two pictures.....
bevel width
It's the scale that escapes me
Re: It's the scale that escapes me
Looking forward to it, thanks! *NM*
More on the Weaver Bevel
Re: More on the Weaver Bevel
the premise is different in this case
I don't agree with limitation of your premise
You nailed it
This is hilarious
Jim - here's your guy
Well that escalated quickly.
Moving the needle
Re: Moving the needle *LINK*
Thanks for the memories *PIC*
Absolutely *LINK*
Positioning *LINK*
Where to find unhndled Narex chisels? *NM*
Taylor Tool Works
narex and their hardening....
how I achieved the Weaver Bever
Weaver Bevel
Further defining the Weaver Bevel
solving a problem, not creating one...
Re: solving a problem, not creating one...
BTW
rolling over edges....
On secrets, incantations and open source
Weaver grind—how is convexity added?
Marc Adams
Could've been felt...
Re: Weaver grind—how is convexity added?
The world is upside down :)
I took a nine day Sellers course
Re: I took a nine day Sellers course
it makes sense
How about making a video?
Period costume?
Re: How about making a video?
Trying things out
Re: Trying things out
failed to figure things out...
variations on the already done...
thoughts *PIC*
Re: Weaver chisel grind
making peculiar names
