variations on the already done...
David Weaver
..there's nothing really new about this other than the use of the buffer, but I"m sure that that's only new to me.
But as you point out, it's kind of the same thing as other things other than the bits where it's not. Why the buffer? I couldn't tell you exactly- for some reason, the ease with the buffer is better, and the sharpness is higher than doing it by hand. I think the lack of conviction in the abrasive on the buffer just does a finer job in a few seconds than I can do much longer on a strop and there's never an issue with contamination. That's a productive laziness thing for me. Debatable (I wouldn't take the pro side) that it's really significantly different than just rolling the very edge by hand.
As to how it's different than a tiny flat microbevel, I haven't experimented with trying to dial in numerical little flat facets, but figuring out what's what probably wouldn't be hard.
Vs sellers? There's less primary and secondary angle behind the edge so the wedging is less. You're also working only a tiny part of the bevel by hand (the secondary and then the tiny line) and can chase it off with a regrind. I think most people will tend to make a fairly blunt bit of steel behind the edge with sellers' method (a large amount of it) though that's the fault of the method and not the user. I guess you could more or less point this out to be the same thing if you just drew a profile of the edge, picked an arbitrary spot and then drew a secant line eliminating any of the rounding not needed.
Knives may have brought me to this - I do the same thing (But by hand) with japanese knives - very thin bevel profile, enough strength at the edge so that they don't chip.
It's a little bit embarrassing to have my name stuck to it as I'm sure there are a lot of carvers who have done something similar over the years.
But the kicker (other than just rolling the very tip) that made me bring this up was using an incannel gouge and sorby chisel that were both sharper off of the buffer in a couple of seconds than I can ever get them by hand, and the cutting resistance seems less than an ideal single bevel that would hold up as well.
no good for planes, though.
Messages In This Thread
Weaver chisel grind *PIC*
Some quick tests (lots of pictures) *PIC*
Some chisel pictures *PIC*
Re: Some chisel pictures
Re: Some chisel pictures *PIC*
astonished by picture quality *NM*
excellent pictures!
Another test *PIC*
Re: Another test
question
Re: question *PIC*
Re: question
could be a database issue...
Second try for picture *PIC*
yellow pine *NM*
Those pictures..
Nice piece of work
Re: Nice piece of work
Light source?
Re: Light source?
stitches.....
I've made a video.....
video...not for the meek...
It's a very funny video
comments on the two pictures.....
bevel width
It's the scale that escapes me
Re: It's the scale that escapes me
Looking forward to it, thanks! *NM*
More on the Weaver Bevel
Re: More on the Weaver Bevel
the premise is different in this case
I don't agree with limitation of your premise
You nailed it
This is hilarious
Jim - here's your guy
Well that escalated quickly.
Moving the needle
Re: Moving the needle *LINK*
Thanks for the memories *PIC*
Absolutely *LINK*
Positioning *LINK*
Where to find unhndled Narex chisels? *NM*
Taylor Tool Works
narex and their hardening....
how I achieved the Weaver Bever
Weaver Bevel
Further defining the Weaver Bevel
perception of penetration?
solving a problem, not creating one...
Re: solving a problem, not creating one...
BTW
rolling over edges....
On secrets, incantations and open source
Weaver grind—how is convexity added?
Marc Adams
Could've been felt...
Re: Weaver grind—how is convexity added?
The world is upside down :)
I took a nine day Sellers course
Re: I took a nine day Sellers course
it makes sense
How about making a video?
Period costume?
Re: How about making a video?
Trying things out
Re: Trying things out
failed to figure things out...
thoughts *PIC*
Re: Weaver chisel grind
making peculiar names
