I haven't seen it....
Re: Calling BS ()
David Weaver
...in my use, but I've seen abused planes just as Joel has (and you have) that may give someone the notion that a completely worn out plane is normal.
I'd imagine that anything worn out either planed dirty wood (or wood with foreign objects in it) and was intentionally abused, or was used for a single task and due to the low cost, abused when it was trued (as in belt sanded or run across a power jointer).
I've got one try plane that has probably trued about 750 board feet of cherry, beech, walnut, rosewood and mahogany. I've trued the sole once (how much, I don't know - the thickness of a sheet of paper or two) as the only thing that I can find that actually puts fast wear on a wooden plane is dedicating one to jointing a whole bunch of rough lumber with no other use (they'll wear hollow in the center).
More common to find a used plane with a spent iron or a replacement.
The treatment and constant tuning of japanese planes makes the relationship go the other way (n bodies per iron and n irons per body in western are probably not that different of an n)
Messages In This Thread
Light vs Heavy planes
Re: Light vs Heavy planes
I like tools from Brooklyn
Re: I like tools from Brooklyn *NM*
Infills in the UK
I'm glad you commented.
Weight Comparison
more infill weights
Re: more infill weights
initial fitting...
one more follow-up comment.
Re: one more follow-up comment.
rosewood
Re: rosewood
now there is a pearl of wisdom
Re: I'm glad you commented.
what I've found...
Re: what I've found...
Re: Calling BS
Re: Calling BS
Re: Can't argue
Re: Calling BS
by the early 19th century
Re: by the early 19th century
It's not offered as ball court...
Re: It's not offered as ball court...
I'm guessing on parts here...
I miss Todd Hughes' contributions too *NM*
Re: Calling BS
Re: Calling BS
I think we're agreeing...
Re: I think we're agreeing...
Re: Me too
Wood isn't indefinitely stable, either
Re: Facts, not assertions
Re: I haven't seen it....
Truing Kanna
expanding on what jim said
Coupla thoughts
different methods of lapping and the bump
interesting that...
Note on a modern infill
konrad's planes...
new vs. old planes...
Turnover, newbies and FAQ
comment on teaching
If you get my drift...
finding out who to listen to...
Re: finding out who to listen to...
I agree...
Re: Same
Old history
Misprint?
Re: Misprint?
cultural thing...
Shops using mostly hand tools..
Re: Shops using mostly hand tools..
Don felder's guitar...
Not a positive contribution to the discussion
Inertia and figured wood
Re: Jim, what is Osae-gani? *NM*
Osae-gani
Re: Osae-gani
Note on fitting
biases for the maker...
Re:wedge fitting
Re:wedge fitting
funny...
Re: funny...
At some point..
The experiment and conclusion are both confusing
Re: Heavy and light
another factor
If you're trimming furniture...
The best case for heavy planes...
Re: reframing the issue
Friction, and more
not the direction I went *PIC*
5 1/4
