Re: Osae-gani
Osae-gani ()
David Weaver
Raney chewed me out once because I said that the planes are relatively simple. They are in the same way many hand made things are. You can generally get an iron and build a dai around it and if you feel the need for a ledge, you can faff with that.
But ultimately, fitting wooden planes is fitting wooden planes.
Some things are reversed (which I think is where raney was getting tied up in thinking things are complicated) - the bed of the plane is convex instead of flat or slightly concave (And the irons are made to match it a little bit. Not sure that with the weight of the iron, the convexity is much more than an artifact of fitting at the edges.
The tapers are reversed and the abutments have to be precise enough since there's no wedge - precise enough to keep the iron tight but not prevent it from getting it to the end of the plane.
And rather than the body of the plane outlasting several irons, the irons outlast several dais.
But more than most other planes, they're best for someone who is constantly using and adjusting a plane, and best for clean wood (the penalty for nicks is severe in terms of time).
separately, I remember reading a japanese retailer or instruction site translated via google that was describing the care requirements and movement of the planes. It said something flatly like "if you are a casual user who may use a plane and then have weeks or months before you use it again, you shouldn't consider using japanese planes. They will not work well after a time of inattention and such a user will spend more time adjusting the plane than using".
Well, there goes the boutique market!! The guy who got me into woodworking goes several years between uses with some of his planes.
Messages In This Thread
Light vs Heavy planes
Re: Light vs Heavy planes
I like tools from Brooklyn
Re: I like tools from Brooklyn *NM*
Infills in the UK
I'm glad you commented.
Weight Comparison
more infill weights
Re: more infill weights
initial fitting...
one more follow-up comment.
Re: one more follow-up comment.
rosewood
Re: rosewood
now there is a pearl of wisdom
Re: I'm glad you commented.
what I've found...
Re: what I've found...
Re: Calling BS
Re: Calling BS
Re: Can't argue
Re: Calling BS
by the early 19th century
Re: by the early 19th century
It's not offered as ball court...
Re: It's not offered as ball court...
I'm guessing on parts here...
I miss Todd Hughes' contributions too *NM*
Re: Calling BS
Re: Calling BS
I think we're agreeing...
Re: I think we're agreeing...
Re: Me too
Wood isn't indefinitely stable, either
Re: Facts, not assertions
I haven't seen it....
Re: I haven't seen it....
Truing Kanna
expanding on what jim said
Coupla thoughts
different methods of lapping and the bump
interesting that...
Note on a modern infill
konrad's planes...
new vs. old planes...
Turnover, newbies and FAQ
comment on teaching
If you get my drift...
finding out who to listen to...
Re: finding out who to listen to...
I agree...
Re: Same
Old history
Misprint?
Re: Misprint?
cultural thing...
Shops using mostly hand tools..
Re: Shops using mostly hand tools..
Don felder's guitar...
Not a positive contribution to the discussion
Inertia and figured wood
Re: Jim, what is Osae-gani? *NM*
Osae-gani
Re: Osae-gani
Note on fitting
biases for the maker...
Re:wedge fitting
Re:wedge fitting
funny...
Re: funny...
At some point..
The experiment and conclusion are both confusing
Re: Heavy and light
another factor
If you're trimming furniture...
The best case for heavy planes...
Re: reframing the issue
Friction, and more
not the direction I went *PIC*
5 1/4
