Re: Hollow grind on a butt chisel?
William Duffield
Do you have a 1-2-3 block? If so, and you have some bolts to fit it, you can bolt the butt chisel to one of the faces of the block and set it on your flat grinder platform. If this technique is not clear, here is an example, at about 3:00, which happens to be a bit more complicated than grinding a butt chisel.
https://www.youtube.com/watch?v=MFGdSAiQGBc&frags=pl%2Cwn
