AlanWS
When I've cut hexagonal stock (as a driveshaft for a grain auger to use in moving sawdust to allow a shorter cyclone with a large bin -- unfortunately it didn't work well: planer shavings are not like grain,) the easiest way I found was to cut a rectangular cross section with a 1:1.732 ratio (sqrt 3). The short side measures the face to face distance across the final hexagon, and the long side is the point to point distance.
I cut it by tilting the tablesaw sawblade 30 degrees from square away from the fence, allowing 4 rip cuts without changing settings to establish the hexagon. Tweaking was needed only to make sure the cut met the short face halfway up.
A planing jig to hold stock at the correct angle, and a line ruled down the centers of the short faces, might make planing fairly easy. It's harder to describe than the tablesaw approach, which is why I let that leak into the hand tools section.
It's interesting that you need to plane four surfaces, whether you convert to a hexagon or an octagon.
Messages In This Thread
- First successful (sort of) Pencil
- Re: Ducking and Running *LINK*
- A few more...
- Re: one more - shellac french polish
- 6 facets on a pencil instead of 8
- 6 facets is better, but harder
- Re: 6 facets on a pencil instead of 8
- Shellac
- Pencil Two - Octagonal
- Re: First successful (sort of) Pencil
- Re: First successful (sort of) Pencil *LINK*
- Re: First successful (sort of) Pencil *PIC*
- Or, there are circular pencils
- A few more...
