Two questions remain
The original- does chromium oxide have a beneficial properly that proper selection of alumina doesn't match?
And a new one raised by Warren- will proper selection of particle size of the harder abrasives render irrelevant any friability, hardness, etc property of the softer ones. I accept that xx micron diamond will make deeper scratches than xx micron silica. That's why it removes metal vastly faster for equivalent effort. But can you achieve the effect of silica with a finer diamond abrasive? When it comes to visual appearance the answer is yes. Does a historical abrasive do anything beyond remove metal by scratching? No data revealed to suggest it does but one could make a case that it could.
BTW, add silica, hardness about 7, to your tabulation.
Messages In This Thread
Is chromium oxide honing compound still relevant
Marketing with the compounds...
polishing stainless
Re: polishing stainless
G-456--not that it's practical
Or not...illegal to ship?
Re: Is chromium oxide vs aluminum oxide +...
My opinion..
Re: Is chromium oxide honing compound still releva
to repeat the question....
Re: to repeat the question....
sources
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Historical yet again
Historical methods
Enlighten me
Re: Enlighten me
Re: Enlighten me
A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
No clue about historical..
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Re: sources
Wiley you nailed it, I think
Green and white vs. white
Re: Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
PS
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
Appearance...
Re: Appearance...
That is what I am going to experiment with
Visually similar *LINK*
