Historical yet again
I suspect that much of what we consider for final edge refinement has been derived from historical metal polishing. I don't regard edge refinement(polishing the bevel) any different technologically than surface polishing a metal part. This assumption, I'll bet, is widespread. So a woodworker sees someone polishing a piece of metal and says, I could do that to "polish" a chisel bevel. And if it worked the rest is history. That's how I got into diamonds, which I found are now widely used for metal specimen preparation and metal polishing instead of historical abrasives.
If you go back in history I suspect you will find the method you found was developed for metal surface polishing.
Messages In This Thread
Is chromium oxide honing compound still relevant
Marketing with the compounds...
polishing stainless
Re: polishing stainless
G-456--not that it's practical
Or not...illegal to ship?
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Re: Is chromium oxide honing compound still releva
to repeat the question....
Re: to repeat the question....
sources
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Historical methods
Enlighten me
Re: Enlighten me
Re: Enlighten me
A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
No clue about historical..
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Re: sources
Wiley you nailed it, I think
Green and white vs. white
Re: Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
PS
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
Appearance...
Re: Appearance...
That is what I am going to experiment with
Visually similar *LINK*
