Enlighten me
Historical methods ()
I did make an undocumented assumption in referring to chromium oxide as a historical abrasive for metal abrasion relative to alumina. Small particle chromium oxide would be technologically easy to manufacture. No so with submicrom alumina. In referring to chromium oxide as "historical" relative to alumina I made the assumption that people figured out how to make and use chromium oxide as a metal abrasive before submicron alumina. If this assumption is in error enlighten me of the comparative dates for when these materials became used for polishing metal.
(submicron alumina abrasive is not made by simply crushing aluminum oxide and screening)
Messages In This Thread
Is chromium oxide honing compound still relevant
Marketing with the compounds...
polishing stainless
Re: polishing stainless
G-456--not that it's practical
Or not...illegal to ship?
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Re: Is chromium oxide honing compound still releva
to repeat the question....
Re: to repeat the question....
sources
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Historical yet again
Historical methods
Enlighten me
Re: Enlighten me
Re: Enlighten me
A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
No clue about historical..
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Re: sources
Wiley you nailed it, I think
Green and white vs. white
Re: Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
PS
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
Appearance...
Re: Appearance...
That is what I am going to experiment with
Visually similar *LINK*
