Something called the ‘Koch System’
What do I have? ()
Wiley Horne
Found the original marketing description:
https://www.norahall.com/tools_koch.shtml
I don’t recommend these tools and materials in the least. In fact, i ‘m a bit embarrassed. I only bring this method out here, because it’s so unique compared to all the other wheel abrasive offerings. Particularly the heat activation which I can’t fathom.
The fact is, it does yield a sharp sharp edge. However, I was not able to maintain geometry over multiple sharpenings. Would inevitably get rounding over and a steeper bevel. When what I always wanted was to maintain a long low bevel on gouges. So I gave it up for conventional methods. Nora liked it as a final hone, after getting the geometry and a reasonable hone by conventional means. I found that it worked great once, and then things kinda went down hill and I would soon have a major regrinding to do.
Wiley
Messages In This Thread
Is chromium oxide honing compound still relevant
Marketing with the compounds...
polishing stainless
Re: polishing stainless
G-456--not that it's practical
Or not...illegal to ship?
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Re: Is chromium oxide honing compound still releva
to repeat the question....
Re: to repeat the question....
sources
The emphasis on speed...
What do I have?
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Historical yet again
Historical methods
Enlighten me
Re: Enlighten me
Re: Enlighten me
A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
No clue about historical..
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Re: sources
Wiley you nailed it, I think
Green and white vs. white
Re: Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
PS
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
Appearance...
Re: Appearance...
That is what I am going to experiment with
Visually similar *LINK*
