John in NM
Still not cheap, but here's another source that seems cheaper. I would imagine that metal polishing suppliers are cheaper still but that you have to buy a large quantity. I bet the green chrome is cheap due to being used more as a pigment than an abrasive - much bigger market for pigments.
I don't use it on strops, I used to use it polishing rocks. I don't recall CrOx being used much for that, perhaps it is less effective in that regard. I always suspected that a large part of polishing minerals was a chemical action between the polish and the crystal - that was particularly noticeable polishing quartz with Cerium oxide in the surface effects you could see. Alumina generally won't polish quartz either, in spite of being much harder.
Messages In This Thread
- Is chromium oxide honing compound still relevant
- Marketing with the compounds...
- Re: Is chromium oxide vs aluminum oxide +...
- Re: Is chromium oxide honing compound still releva
- to repeat the question....
- Re: to repeat the question....
- sources
- The emphasis on speed...
- Historical methods
- Enlighten me
- Re: Historical methods
- Re: sources
- PS
- Re: to repeat the question.... *LINK*
- sources
