sources
two markets use alumina abrasives in submicron sizes- rock polishing and metal polishing. Searching lapidary supplies will yield sources as will companies that supply material for polishing metal, and metal specimens for metallurgy examination(which is where I used this stuff). It will be available as dry powder and as a suspension. A pint will be about $15. The problem will be finding a small enough quantity as powder. May have to get a pound and sell 95% of it on Ebay!
for example: http://metallographic.com/Technical/Fine%20abrasives.htm
www.metallographic.com/Brochures/alumina2.pdf
It appears that in both applications diamond has replaced other abrasives in these applications. I could not find anyone supplying chromium oxide for metal polishing. Makes me think wood workers are using it for historical reasons rather than effectiveness.
Messages In This Thread
Is chromium oxide honing compound still relevant
Marketing with the compounds...
polishing stainless
Re: polishing stainless
G-456--not that it's practical
Or not...illegal to ship?
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
Re: Is chromium oxide honing compound still releva
to repeat the question....
Re: to repeat the question....
sources
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Historical yet again
Historical methods
Enlighten me
Re: Enlighten me
Re: Enlighten me
A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
No clue about historical..
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Re: sources
Wiley you nailed it, I think
Green and white vs. white
Re: Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
PS
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
Appearance...
Re: Appearance...
That is what I am going to experiment with
Visually similar *LINK*
