Re: Is chromium oxide honing compound still releva
William Duffield
That's what I use. Note that the url is a bit misleading. It is 0.3 micron.
As I said in the other thread, I mix it with mineral oil and stuff it in a Monoject 412 syringe (available through Lee Valley) and apply it to a horse butt strop from TFWW. That little tin is a lifetime supply if you are just using it for honing plane blades and chisels.
I think the Cr2O3 in the green stick from Lee Valley is 9 microns (30 times as coarse), and is mixed with Al2O3.
Messages In This Thread
Is chromium oxide honing compound still relevant
Marketing with the compounds...
polishing stainless
Re: polishing stainless
G-456--not that it's practical
Or not...illegal to ship?
Re: Is chromium oxide vs aluminum oxide +...
Two questions remain
My opinion..
to repeat the question....
Re: to repeat the question....
sources
The emphasis on speed...
What do I have?
Something called the ‘Koch System’
Re: Something called the ‘Koch System’
The wax thing...
Re: The wax thing...
Historical yet again
Historical methods
Enlighten me
Re: Enlighten me
Re: Enlighten me
A minerology lesson
Re: A minerology lesson *LINK*
I stand corrected
No clue about historical..
Re: Historical methods
Extrapolation of scenarios
Re: Extrapolation of scenarios
I hope brian doesn't show up...
Re: I hope brian doesn't show up...
Re: sources
Wiley you nailed it, I think
Green and white vs. white
Re: Wiley you nailed it, I think
Diminishing returns
Re: Diminishing returns
PS
Re: to repeat the question.... *LINK*
Re: Good link, thanks. *NM*
Appearance...
Re: Appearance...
That is what I am going to experiment with
Visually similar *LINK*
