Re: works better when used properlyResponse To:
works better when used properly () Kevin French
I use SS over Diamond plate because I found 50+ pieces of plate glass at the dump. Now I only have the cost of sandpaper. I can set it up with as many grits as I want. The plates are only 3/16" but I have a drop-in frame to add stiffness.
Messages In This Thread
- Scary sharp: replacing sandpaper
- Re: a better idea
- Re: a better idea
- Re: a better idea
- works better when used properly
- The original "Scary Sharp" post (1995)
- Re: works better when used properly
- Re: Scary sharp: replacing sandpaper
- solvent solution and a hair drier solution
- Razor blade...
- Re: a better idea
- Re: a better idea
