Re: same, but details different, and a question
E Phillip Smith
I use a 1/2" wheel with SHALLOW crown. Probably use roughly half the wheel while grinding. I used to use wider wheel but have found MUCH greater variety of wheels for surface grinders and you can buy 1/2" wheels cheaper than the wider wheels so I opt for the narrower wheels as matter of cost and not amount of crown.
I get the impression from Joel's description that he slightly rotates to iron to take advantage of the full wheel width. As much as possible I keep the iron square with the wheel. That slight crown makes grinding a clean edge dramatically easier. Both variations of the technique will work.
Messages In This Thread
Tormek: getting old wheel off?
Re: Tormek: getting old wheel off?
Fear of heat- not an issue
Re: Fear of heat
Re: Fear of heat
Fear of heat- any evidence?
Re: Fear of heat- any evidence?
My set up is like yours...
some heat calculations
More exercises with no exact answers
Re: More exercises with no exact answers
Re: some heat calculations
It sure as hell ain't from heat
Re: Fear of heat- not an issue
Question
Search surface grinder wheels, Type 1 *NM*
Wheel recommendation
Re: Wheel recommendation
Did it. Here are 2 extensive sources:
Re: Did it. Here are 2 extensive sources:
You have identified the problem
Problem 2
David, please link us to
Re: David, please link us to
I did find this I wheel
What this wheel is, technical data, flawed
Re: Fear of heat- not an issue *LINK*
All these problems aren't
already equipped vs. not
Please listen, more issues that aren't......
Re: Please listen, more issues that aren't......
Re: Tormek: getting old wheel of littl
Similar to pulling rusted car wheels
Re: Similar to pulling rusted car wheels
