same, but details different, and a question
Anyone that uses a crowned wheel will understand your description. Some details differ. I use 1/2 x 7" wheels because I use inexpensive surface grinder wheels.(Radiac at lest used to make whatever you wanted in 20 lot batches) I wind up grinding on about 3/8" of the width, which is determined entirely by the depth of the hollow in my case.
If sliding the flat tool back and forth on a tool rest, I can't use any more of the wheel width than what nestles in the hollow, so long as I keep the tool flat on the rest. So, the part I don't understand is how one can use the edges of a 1" wide wheel that is crowned. Are you not using a tool rest?
And agree it is easy to teach. I showed a machinist who ground metal working tools and he proceeded to grind his thin Stanley blade uneventfully, 1st try. I have showed lots of people in the club and all have been successful, even the lady that stuck her finger into the wheel to "see if it was spinning" (left a trail of blood to the first aid station). As one's soft touch becomes refined the need for the coolest slower cutting wheel becomes less. I support the suggestion that learning on a slow speed grinder will be easier, as well as it is fast enough, if the grinder is dedicated and not a multitasker.
My marketing talent has been shown to be near useless, but I'll still suggest that a less expensive 1/2" wheel might result in more sales.
Messages In This Thread
Tormek: getting old wheel off?
Re: Tormek: getting old wheel off?
Fear of heat- not an issue
Re: Fear of heat
Re: Fear of heat
Fear of heat- any evidence?
Re: Fear of heat- any evidence?
My set up is like yours...
some heat calculations
More exercises with no exact answers
Re: More exercises with no exact answers
Re: some heat calculations
It sure as hell ain't from heat
Re: Fear of heat- not an issue
Re: same, but details different, and a question
Question
Search surface grinder wheels, Type 1 *NM*
Wheel recommendation
Re: Wheel recommendation
Did it. Here are 2 extensive sources:
Re: Did it. Here are 2 extensive sources:
You have identified the problem
Problem 2
David, please link us to
Re: David, please link us to
I did find this I wheel
What this wheel is, technical data, flawed
Re: Fear of heat- not an issue *LINK*
All these problems aren't
already equipped vs. not
Please listen, more issues that aren't......
Re: Please listen, more issues that aren't......
Re: Tormek: getting old wheel of littl
Similar to pulling rusted car wheels
Re: Similar to pulling rusted car wheels
