Re: More exercises with no exact answers
John Schtroumpf
Keep in mind that the primary function of the chip breaker is to deflect the shaving. In order to accomplish that without the shaving going under or catching on the chip breaker. A point contact is intentionally made between the leading edge of the chip breaker and the blade. Point contacts do not make good heat sinks because there is little contact surface between the two pieces of metal, so heat transfer is restricted. A standard chip breaker should have no problem dissipating the small amount of heat transferred.
When grinding, if you used a different piece of metal that is optimized as a heat sink. I don't know, but it might make a difference.
Messages In This Thread
Tormek: getting old wheel off?
Re: Tormek: getting old wheel off?
Fear of heat- not an issue
Re: Fear of heat
Re: Fear of heat
Fear of heat- any evidence?
Re: Fear of heat- any evidence?
My set up is like yours...
some heat calculations
Re: some heat calculations
It sure as hell ain't from heat
Re: Fear of heat- not an issue
same, but details different, and a question
Re: same, but details different, and a question
Question
Search surface grinder wheels, Type 1 *NM*
Wheel recommendation
Re: Wheel recommendation
Did it. Here are 2 extensive sources:
Re: Did it. Here are 2 extensive sources:
You have identified the problem
Problem 2
David, please link us to
Re: David, please link us to
I did find this I wheel
What this wheel is, technical data, flawed
Re: Fear of heat- not an issue *LINK*
All these problems aren't
already equipped vs. not
Please listen, more issues that aren't......
Re: Please listen, more issues that aren't......
Re: Tormek: getting old wheel of littl
Similar to pulling rusted car wheels
Re: Similar to pulling rusted car wheels
