More exercises with no exact answers
some heat calculations ()
William Duffield
Could the additional thermal mass of a closely set chip breaker make a significant difference in the rate of heat transfer from the edge, and therefore in the possible loss of hardness of some steels?
If so, could choosing a more thermally conductive steel for the chip breaker result in longer edge retention? Might it even make sense to use a copper or copper clad, or even a silver plated chip breaker?
If the above questions result in improved edge retention, would it also decrease the likelihood of an inexperienced sharpener losing hardness if the chip breaker were left attached to the blade while grinding?
Messages In This Thread
Tormek: getting old wheel off?
Re: Tormek: getting old wheel off?
Fear of heat- not an issue
Re: Fear of heat
Re: Fear of heat
Fear of heat- any evidence?
Re: Fear of heat- any evidence?
My set up is like yours...
Re: More exercises with no exact answers
Re: some heat calculations
It sure as hell ain't from heat
Re: Fear of heat- not an issue
same, but details different, and a question
Re: same, but details different, and a question
Question
Search surface grinder wheels, Type 1 *NM*
Wheel recommendation
Re: Wheel recommendation
Did it. Here are 2 extensive sources:
Re: Did it. Here are 2 extensive sources:
You have identified the problem
Problem 2
David, please link us to
Re: David, please link us to
I did find this I wheel
What this wheel is, technical data, flawed
Re: Fear of heat- not an issue *LINK*
All these problems aren't
already equipped vs. not
Please listen, more issues that aren't......
Re: Please listen, more issues that aren't......
Re: Tormek: getting old wheel of littl
Similar to pulling rusted car wheels
Re: Similar to pulling rusted car wheels
